TwinTurbo.NET: Nissan 300ZX forum - you'll be fine if you completely disable the cylinder
Subject you'll be fine if you completely disable the cylinder
Posted by aliaZ on August 22, 2011 at 5:35 AM
  This message has been viewed 151 times.
In Reply To how bad is it to drive posted by mikehawkhertz on August 21, 2011 at 08:29 PM
Message with the bad injector by pulling the injector connector
A failing injector often runs lean prior to complete failure. Unplugging it will prevent this from happening
